K
I am trying to write code that when a count reaches certain number it should reduce the force by 25.
In my first line of code whenever the pulse count is 7000 the force decreases by 50. The problem is that my count could be 7000 for a second and plc could scan through the codes execute X numbers of times in a second. Meaning that you would be subtracting 50 times X number of times before it goes to 7001. How do i make sure that my initial settings will not be overwriting my changes every program cycle. Any inputs will greatly be appreciated.
