Hi, all,
New to Modbus.
Trying to make a software simulator as Modbus device and sends back a small database content when requested. Now just trying with a ASCII file. What is best way to store this content as Modbus object?
appreciate your help very much in advance.
New to Modbus.
Your question is not very clear. What do you mean by "store this content as Modbus object"?
Modbus is a communications protocol. Modbus servers (or slaves) normally represent their data as a data table of registers, coils, and discrete inputs. It may be convenient to store the data in an array. However, it is really up to whatever is most convenient for your implementation.
If your Modbus Server (slave) needs to run on Windows, check out Automated Solutions website for a Modbus Slave ActiveX Control that supports RTU, ASCII, and TCP.
Your application just reads/writes register arrays on the ActiveX Control. The ActiveX Control then handles all the Modbus stuff behind the scenes.
http://automatedsolutions.com/products/modbusslave.asp
-Mark
-Mark
I think you are asking for a ModBus Slave Simulation application that will respond to any ModBus Host poll. If that is the case what application are you using as a Modbus Host? Are you wanting to do this with a Modbus Slave that runs on WIN32? Also, are you wanting to do this with Serial Ports or Ethernet?
You can implement this with our rlModbus class for example.
http://pvbrowser.de/pvbrowser/sf/manual/rllib/html/classrlModbus.ht ml
or google: rlmodbus
This will work on almost any operating system and using TCP or serial line.
Use our project
http://pvbrowser.org
or google: rlmodbus
Use our project
"First things first -- but not necessarily in that order"
-- The Doctor, "Doctor Who"
