present situation-diff transducer (+) leg is connected to furnace pressure & (-) leg opn to atmostphere.
What will Happen if i will calibrate my transducer (RANGE>>-2mbar to +2mbar) in negative leg only by suction & press of -2mbar & +2mbar AND connect negative leg to measurement line & Positive leg open to atmostphere. Will it work? kindly read well to understand topic & suggest me.
