Greetings to you all,
I had used Monitor Pro as an OPC server before, The OPC client application is a custom application.
I knew that each OPC client required a "CAL" license.
Now, We need to connect different SCADA system to Monitor Pro. we think of making Monitor Pro as the OPC client. will it required "CAL" ?
Any other thoughts?
Thanks in advance
Ayman
Any other thoughts?
Thanks in advance
Ayman
