L
We have a Siemens 300 PLC with CPU (local program). There's a Schneider (Telemecanique) Modicon XBT H011010 display connected with the CPU via an MPI-bus adapter. It's all working fine but now we need to change some alarm settings on the display.
We have a backup of the old configuration of the display. It's a file with extension *.mop. The file was created using XBT-L1000 V3.50 software. However, we don't have that software anymore, instead we have XBT-L1000 V4.42 software.
Now, when trying to open the *.mop file with XBT-L1000 V4.42 a message "This is not an XBT-L1000 file" appears. The software is of a newer release so I would expect no problems.
What's going wrong? Could it be that our software or maybe the file is corrupt and can you suggest a possible solution.
Thanks in advance.
Lode
Thanks in advance.
Lode
