V
DC motor or electro brake?? which is better to apply torque on shaft
Our application:
Testing a electric motor actuator, with rotary motion
(shaft dia:10 mm, it operates only : 0 (close) to 100 (open) degrees, travel time : 5 seconds)
Requirements:
Need to apply torque to the shaft (actuator), in range 0-28Nm (250in-lb), control using PC.
1) Torque loading component (DC motor or electro brake)
2) Controller (feature to interface with PC)
3) If available Encoder to sense angular travel: (0-100 deg. tolerance ± 0.8 deg.)
If seek solution, for the above, which is better soultion (DC motor or electro brake) to apply toque to a shaft (which has rotation limited to 0 - 100 degree) would be good solution.
Thanks & Regards
vish
Our application:
Requirements:
Thanks & Regards
vish
