Just to give you a background, I was once employed in the automotive electronics industry but have now semi-retired and occupy my time working on the electrical systems of narrow boats on the UK canal network. Not much money in it but it is a lovely way of life.
I often get involved in wiring up boats with smallish vintage diesel engines that are preferred in historic or replica historic boats. A lot of these engines were produced without electrical starting systems and it can be difficult to retro fit them because there is no ring gear on the flywheel or mounting for the starter.
One thing that is often installed along with the engine is a large alternator. This is necessary to supply the power to recharge the battery banks that then feed an inverter for mains power. An alternator that is often used is capable of producing 160A DC and is a three-phase stator exited by a 16-pole rotor. The rotor is magnetised by a single DC bobbin coil and is brushless. So that the alternator can be driven to maximum it's speed of 8000rpm by an engine that will only do 1200rpm, it is belt driven with a 1:6.7 pulley ratio.
It occurred to me that it ought to be possible to drive the alternator as a motor by injecting a three phase signal into the rotor windings whilst supplying the rotor directly and thus turn the engine sufficiently fast to start it. At a guess the engine would need to be turned at about 200rpm to start it. This would require the alternator to be driven at 1334rpm and form the phase/pole ratio; the frequency of the signal would have to be 178Hz. I am quite prepared to be corrected on these calculations though! As a guesstimate, I if the output of the alternator is 160A then the locked rotor current would probably be about 200A.
I am guessing again that what I need in the way of control is a switch which when made starts the process at a low frequency and slowly ramps it up to full speed over a couple of seconds and then maintains it at that speed. When the switch was released the process would be stopped. There are a couple of other technical issues such as how to integrate this with the alternators original purpose and some sort of interlock to prevent the starting system being engaged when the engine was already running but these can be sorted out later if I can get the thing motoring.
I have been looking for a BLDC controller/driver IC that has analogue or simple switch inputs, as narrow boats are best kept simple and their owners abhor too much technology but I have not had much success.
I would be grateful for any pointers that you may have...
Arnot
Arnot
