Hi there,
I have to develop simple application which will connect to Simatic 300 and receive the data from it (Format data block from screen shot in configuration panel is -> DB29 and length = 32)
Im using for it library libnodave but Im new in this area of knowledge so I have few questions.
1. I made connection to PLC VIA TCP (.opensocket (102.IP))
2. I receive simple data using dc.readybytes(daveDB,29,0,32,buffer) but the results are like some numbers (I believe there are bytes). What I need to do with it know ? I'm trying to encode it using System.Text.Encoding.ASII.getString(buffer) but there is nothing in there...
3. My application has to work all the time, and in each x minutes has to check if the data are from the PLC, which is the best way to do it? Using thread and loop while() is good one ?
4. If I want to receive data from PLC what I need to know ? Do I need to send any information to PLC for start receive data ??
If you have any examples, I will be appreciate.
Emil
Emil
Emil,
If I can recommend something then I would purchase a SIMATIC NET S7-lean driver.
Configure the SIMATIC NET OPC Server in your PC and create a S7-connection between the S7-OPC Server in the PC and the PLC.
Then use the "SIMATIC NET OPC Data Control" in your VB application to talk with the OPC Server.
You will have to master OPC and S7 communication, but the VB interface of the OPC ActiveX control is very straight forward. It supports read/write as well as async event notification with almost no coding in your VB application
Kind regards
Ronald Nijssen
Kind regards
Ronald Nijssen
"In order to make an apple pie from scratch, you must first create the
universe."
-- Carl Sagan, Cosmos
MatrikonOPC has over 500 OPC interfaces and out of the box software. Find an OPC Server for your devices here.
