Hi greetings!
I was using QuickPanel QPI-ABR-201 (WITH REMOTE IO PORT) connected to 1747-SN. My HMI is broken so i purchased new Fanuc Quick panel.
Model: IC754VSI12CTD which has RS232/485 port. How can I link this to my 1747-SN. I am using SLC 5/04.
My processor has RS232 port if I communicate with this i have to change my ladder program. This is don't want to do. I want to do it through existing scanner module to communicate my screen and PLC module. how?
Any converters are there from RS232/485 to Remote IO
Please explain the possibilities
The possibility is that what you want to do is impossible with the HMI you bought. Based on a quick search, it appears that GE/Fanuc no longer supports the A-B Remote I/O module. However, these QuickPanels are made by Xycom, which is now ProFace, and they still offer the Remote I/O option. Your local distributor can cross-reference you old HMI to a current model.
By the way, QPR-ABR-201 is only the part number for the RIO adapter mounted on your old HMI. The actual HMI has its own part number.
Mike
Mike
Thank you for your feed back
But can I buy a converter which has rs485 to Remote IO protocol option. If so please help me to chose
Food for thought is no substitute for the real thing.
-- Walt Kelly, "Putluck Pogo"
