E
Dear friends,
In our natural gas combined cycle power plant we use seawater as cooling water. We need a system that will detect and monitor the oil level on seawater in the intake area. I've found that GE has a system called Leakwise ID-227 and Arjay Engineering has a system called 2114-HCF. Both of them are using floating sensors but they are using different techniques for measuring.
My question is that which one of them gives more accurate results. Do you have any experiences on them and is there any other company which has a system to measure the oil level?
Thank you for your valuable helps
