P
Can someone give me a guide on the steps in writing up a datasheet for selecting control valves? I notice it is not as straight forward as other instruments.
Do all linear positioner & valve perform the same say, say opening 10% = 10% flow? If it's equal percentage they would be different?
So assuming I'm using 4-20mA I/P positioner which output instrument air, how do I match the Positioner against the Valve? Do i refer to some sort of curve graphs?
Also after installation, how does the Process Controller control the valve openings? Looking at vendor datasheets it doesn't tell much how the valves & positioner would react & their parameters. How do the engineers program the valve so correct current signal will go to positioner which output correct instrument air as end result having correct opening on the control valve?
