Does anyone know if there is a TwinCAT PLC library to interface to a TCP/IP stack?
Am currently using a SICK CLV622 barcode reader, which sends the barcode string out a TCP/IP port (configurable) each time a read is triggered. I wish to read this into a TwinCAT PLC running on a PC also on the network.
yes. Direct access to TCP/IP Stack is available for TwinCAT. It's called the "TwinCAT TCP/IP Library"
http://www.beckhoffautomation.com/english/download/supplement_com.h tm?id=71004577100492
The chief cause of problems is solutions.
