H
Dear All,
We have two level of control i.e. Local and Central. But we are going to adopt two different SCADA systems due to performance and cost issues.
Basically, Wonderware SCADA will be installed at local level, it will collect all data from field PLC/RTU then put data into its real time database server.
In central, we are going to use a SCADA system which is under Linux OS. Its real time database will collect all data from different Local Wonderware server via OPC.
My question is: As I know OPC (not Web based OPC) is not running well in Linux based OS, what will be easier for implementing above system?
Thank you very much.
hlliu
hlliu
