from the Forum department...
siemens plc programmer sw for vista operation system
Posted by ali on 11 November, 2009 - 1:57 pm
hi everyone,
i'm trying to install siemens step7 sw for plc, but i have faced a problem because of my operation system. i'm working on vista, but its not suitable for working on that operation system.
could anyone advise me in this issue?
another sw or doing some modifications ?
thanks in advance
Posted by smallsnowball on 11 November, 2009 - 10:56 pm
Hi ail,
Please look at this website to search for your step7 compatibility with your OS
http://support.automation.siemens.com/WW/view/en/8250891
hope this helps!
with regards,
smallsnowball
Posted by M Griffin on 12 November, 2009 - 12:01 am
Some of the newest versions of Step 7 will work with some versions of MS Windows Vista. Which of the many versions of Step 7 works with which of the many versions of MS Windows however is a very long and complicated subject.
If you go to the Siemens support and service web site and look for the information on Step 7 "service pack" updates it will give the details there. You will need to have all the details however of exactly what version and level of Step 7 you have, what Step 7 options you have, and which exact version of MS Windows Vista you have. Once you have that, you can look up whether what you have *should* work.
I said *should* work, because there are no guarantees that an update from Microsoft hasn't broken something else recently. I haven't tried this yet, so I am just going on the published information.
If you are using MS Windows 7 the situation should be pretty much the same as with MS Windows Vista, as their latest version of Windows (version 6.1) is just a minor update to Vista (version 6.0). However, again there are no guarantees there either.
Posted by HattedOne on 13 November, 2009 - 4:17 am
With both Vista and Windows 7, the editions of the OS are important. Home Premium is not supported, Business (Vista) or Professional (Win7) or above are required along with the latest Step 7 v5.4 service pack.
Windows 7 is not yet supported by Siemens so don't try to ask them for help! Specialist mods to the .msi install files are required to recognise the new OS and install natively.
I got it working quickly by installing into the Windows Virtual PC (with provides an XP runtime) and then using Windows 7 XP Mode to bring the Step 7 window into Windows 7 as-if running natively.
Until Siemens brings out a service pack and supports Windows 7, I will not be relying on a Win7 machine for actual paid work.
Posted by ali on 16 November, 2009 - 1:58 am
thanks all of you for your explanations. i got that i cant use this sw on my pc. i'm using windows home edition. it looks they don't support home edition of vista. i've tried to install step7 version 5.4
Save the whales. Collect the whole set.
Advertise here
Advertisement
our advertisers
