We're having intermittent cable faults on our LCN. The system has been checked from top to bottom. Fiber has less than 2db of signal loss (checked using HW procedure), although it is long run (close to max. distance). LCNE boards have been replaced, grounding checked, LCN cables replaced, terminators checked or replaced, ext. LCN has been physically isolated and terminated with just a couple of nodes and still had B cable problems. Faults normally start on B cable but have began showing up on A. Can someone explain why breaking the B cable connection at the home end would clear errors (temporarily)? System has run for hours or days before faulting??? Any wisdom would be appreciated.
