Dimension of HT cable
R
rab
We must replace an overhead 366 mm2 Alu HT cable with an underground Cu cable 66 kV and we must transmit 37 MW maxi. The 366 mm2 was designed to transmit twice 37 MW .
3 single core Cu cables will be installed in a cable trench. Can you tell us what is the dimension of the CU cable needed.
