Hi All,
I have a Baldor FlexDrive (about 10 yrs old) along with a Baldor BSM50N-375AA motor which I want to configure so that the motor will rotate 360 degrees when following the output from an optical shaft encoder that can produces 1024 pulses per revolution.
In the setup software (Flex, V1.09) there are 3 available operation modes - current mode, velocity mode and pulse following, can someone explain the meaning of each please.
I have run the desktop control software using COM1 connecting the PC to the controller, and the controller attached to the motor's resolver.
With the motor disabled, I see 65536 (actually +-32k) counts per rotation of the motor (by hand), does that sound reasonable ?
Flex appears to be a 16 bit app. Are there any known issues running this using XP ?
Also, are there any well written tutorials that I might benefit from reading ? The whole world of industrial servo control is quite new to me and I keep tripping up over terminology issues.
Many thanks,
Mark
Many thanks,
Mark
