We have several vessels that have scales on them. Recently I was given the "opportunity" to calibrate each of them. Now that I have done this I measured the mv/V output at each of the Digital/Analog transmitters. Each of the scales gets its signal from 3 load cells. Each of the load cells has a different output.
For example; scale D-1's load cell list [email protected]/V
[email protected]/V
[email protected]/V
At 3300 lbs I am reading 6.305mvDC. Does this seem correct? What is the formula for calculating the total output I should be receiving?
Thanks for your help.
[email protected]/V
[email protected]/V
