Go to tools-> bulk edit parameters -> create bulk edit list.
This will list out all the CMs in your control builder, select the CMs you want, select the parameters you want in your excel sheet, supply the path where you want the excel sheet to be created and that's it.
You can use this tool to make multiple changes in multiple CMs at one go.
