WinCC OPC A&E
Saad
My PCS7 is communicating with a Yogogawa system over OPC A&E. The problem is that Yokogawa apparently has some limitations when it comes to configuring their OPC A&E Client. They want us to provie them the data in a sequence dictated by them. They need Source as # 1, Alarm as # 2, etc etc. WinCC follows a different sequence. Is there a config file in WinCC that I can modify to change the current sequence or remove certain components?
