pressure transducer cable colors
P
peter berry
Hi all
I have come into the possession of a pressure transducer that appears to have come from the UK, England to be more correct.
the information shown appears on the manufacturer's label, type rv24
ser no 723 range 0-100 psi from transducers (cel) limited reading England.
the question i have is this. the colours used in the cable, light green yellow red and blue. the colours i am not familiar with or i should say their usage, ie which wires are the supply and which are the output. I have seen green white red and black used in load cells so. Does any one now of either the company or the colour code?
thanks in advance.
If you need other info like it is cylindrical shaped about 40mm round by 50mm tall with a quarter bsp nipple as an attachment.
