We have a 3 PH 480 Arc welder that is being used to weld some pieces on a conveyor chain. The employee welding pieces on is using an overhead crane/trolley type chain hoist. It is also 480V 3 PH and is supplied from same source as welding machine.
The work (conv chain) is attached to work (ground) lead of the welding machine. The stinger does not have to be near piece for this to happen and isn't involved. If work is touched by the hook of chain hoist he is using, it sparks violently. The machine is set to dc+ on electrode, so that would mean work piece is dc-, correct? DC flows from - to +, so I reversed polarity of machine, but it still sparked when work was touched by chain hook of chain hoist.
I did not read any voltage from chain hoist hook to ground. I tried switching power off at breaker on hoist, same result. Ground (work) lead of machine must be making good contact, but what causes this to happen? I am stumped.
