G
We have a slowly rotating (10 rpm) cylindrical vessel (18" dia X 40" h) in which we wish to measure and control the level of a hot steaming (200 degF) liquid. Because of mechanical constraints, we cannot access the top of the vessel. The lower sides of the vessel also have very limited space available (aprox 1.75" x 2.0"). The bottom is also not accessible.
Most of the wireless offerings today are too bulky to fit into the limited space available on the lower sides....and.... As the machine is only used once or twice a week, battery life could only be extended if there was an easy way to turn the device off. Most do not have this feature.
I am wondering if anyone has seen any compact pressure sensors that are combined with appropriate RFID technology which could be used as a possible solution. Any other suggestions?
Yikes...Almost forgot...it's all in a washdown environment.
Thanks in advance for your feedback
Cheers
Gerald Beaudoin
Cheers
Gerald Beaudoin
