P
We are using Micro Motion F-Series Flow Meters to measure the Flow of Oil and Water at Test Separator outlet. F200H (Note:-01) with Transmitter 1700 is used to measure Water Flow (Range 0 to 1800 USB/day) & F300H (Note:-02) with transmitter 1700 is used to measure Oil Flow (Range 0 to 5000 USB/Day). Please answer the following;
1. What is the minimum flow that can be accurately measured by each meter?
2. How to compensate the flow so that we can get Standard USB/day flow? (I understand that mass flow meter is measuring Actual USB/Day Flow; i.e. mass-flow divide by actual density )
<pre>
Note: 1 F200H 999 C C A Z E Z Z Z X 17017 NTMC with Transmitter 1700 | 11DEFEZZX _13079
Note: 2 F300H 999 C C A Z E Z Z Z X 1642 HTMC with Transmitter 1700 | 11DEFEZZX _13079</pre>
<pre>
