I work with testing & commissioning jobs. Recently while charging a 5MVA power transformer DYn11, 33/11KV, I noticed a strange phenomenon. The transformer was drawing about 1.1MW power without any load in secondary. I checked the circuit breaker in primary 33kv side & found that the B-phase pole contact was not proper. I adjusted the penetration of B-phase pole contact & the problem was solved. But my question is how is it possible? How a transformer draws so much current in idle condition & how this circuit breaker problem relates to it?
Thanks and regards
Ashutosh
ashutoshb [at] engineer.com
Thanks and regards
Ashutosh
