F
I am an engineer student currently building a generator from a shaded-pole motor (Fasco model D289: 6 coils, 120v, 1050 RPM). I plan to modify the rotor with permanent magnets, so that the rotation of the rotor will induce current in the armature coil. my question is:
Will the armature be more efficient at generating electricity with or without the shading coils? In other words should I keep the shading coils around the pole peace or should I remove them?
An other question from the above question. If I am to remove the shading coils: should I remove them completely or can I just cut the ring so that it is not continuous anymore?
Thank You for your answer
Francis
franc_08 [at] hotmail.com
Francis
