Modbus response
Michael
Hello everybody. This is my first post.
I've a problem. I need to communicate with a modbus device. i know all the parametrs (function id,address,etc). I put this script in matlab an a receive a message: "The specified amount of data was not returned within the Timeout period.", and the output its empty.
Code:
S = serial('COM1','Baudrate',9600,'DataBits',8,'StopBits',1,'Parity','none','Timeout',10)
fopen(S);
aa='00041036004014E5';
fwrite(S,aa);
output=fread(S);
fclose(S)
Thanks to all
Bob Peterson
I am not going to waste time looking up what this message is supposed to do.
Is this ASCII or RTU? It looks like RTU but it appears like a string variable is being used. I don't know anything about matlab so that part of it is foreign to me.
How did you determine the message string?
It's RTU. I determined the string with other application , and i had a correct response by the device.
bob peterson
I think that may be your problem. i think you are sending it an ascii string when it should be hex.
Bob
curt wuollet
That looks like either a complete failure to communicate or possibly you aren't waiting long enough. The port timeout may not be the same as the reply timeout. Try putting a delay between writing and reading. I don't do matlab, but I do know some devices take their time in responding.
cww
I think it would be more precise to say that the "string" should be an array of raw binary bytes. That is often represented on a monitor as escaped hexadecimal, but it's raw binary data.
It is important to make this distinction in this particular case, because while Modbus/RTU uses binary data, Modbus ASCII messages are of course hexadecimal ASCII digits. It's important not to confuse the two.
I think that you have the right idea. My problem it's how do i send the values in hex from matlab! I didn't see any information about that.
Thanks for helping me
Ok. Thanks for the sugestion. My question is: in matlab i send that array of bytes in hex type or i convert that array in hex to binary and then, send to the device?!
regards
But i dont get any error message. My big problem it's how to send data form matlab. I dont know how to put the data to send. If the data type it's hex or convert to binary?!
V
Though this thread is very old, but I came across the same problem so writing the solution over here, which I found on web.
Slightly modified version of your program will work.
S = serial('COM1','Baudrate',9600,'DataBits',8,'StopBits',1,'Parity','none ','Timeout',10)
fopen(S);
aa=uint8(hex2dec(['00';'04';'10';'36';'00';'40';'14';'E5']));
fwrite(S,aa);
output=dec2hex(fread(S));
fclose(S);
