T
I'm a retired calibration & controls guy.
I have a client with a testing machine that uses a 60 tooth wheel for rpm. The sensor (magnetic? hall effect? prox?) was lost. Of course, no records. The sensor's output was sent to an f/v converter - Analog Decives, Inc. 5B45-05.
Spec. pdf is at:
http://www.analog.com/static/imported-files/data_sheets/5B45_46.pdf
I would like to find a 3/8"x1" hall effect or magnetic sensor that would work with the existing 5B45 f/v. Alternatively, I could replace the f/v converter with another model that accepts a standard hall effect sensor.
I need to have 0-5vdc = 0-10,000rpm output from the replacement.
I can even go to a photo sensor, if you think it best. There's a 6-black/6-white disk I can use for that.
Thanks for your help.
Spec. pdf is at:
