P
We are interfacing PLC giving data in BCD (Binary Coded Decimal) which to be interfaced with Honeywell EBI-310. We have following format to read data.<pre>
Format Description
IEEEFPB Bytes are big endian format (this is the same as IEEEFP)
IEEEFPBB Bytes are byte-swapped big endian format
IEEEFPL Bytes are little endian format
IEEEFPLB Bytes are byte-swapped little endian format</pre>
My question is data in BCD format can be taken in any of the above format. Please advice.
PT
Format Description
PT
