G
Could use some help. CAT tech came out twice and couldn't figure it out.
Status: Running 480V/60Hz @ 1800rpm to supply 230Vac and 690Vac to supply 1000Vdc.
Problem: While Genset runs constantly @1800rpm and breaker CLOSED with little load on 690Vac and 230Vac, no problems. The problem is when we run 1000Vdc Draworks, the breaker will trip and the engine will shut off. Through process of elimination, we ruled out the EMCP 3.2, Voltage Regulator, and the breaker itself (Micrologic 6.0A/ RG 1600). On the O/P Relay I see pins 4 and 7. The fault ACTIVE is Custom Event #4 High SHUTDOWN. I suspect Reverse Power relay which is supplied 24Vdc through other safety/fault features (ie: Door Switch) or the connections going to Reverse Power relay.
