R
Hi every body,
In our power plant, there are two GE FRAME 9E gas turbine with MKV TMR.I have noticed the power supply data from DIAGC DATA display - TCQAG1B for core R are as follow:<pre>
P5v = 5.11 vdc
P15a = - 0.12 vdc ( JE - 29 = -0.02 )
N15a = 17.09 vdc ( 30 = 3.00 )
P15b = 9.45 vdc ( 31 = 1.55 )
N15b = -17.1 vdc ( 32 = -3.00 )
P125v= 1.98 vdc ( 33 = 0.04 )
N125v= 152.89 vdc ( 34 = 3.00 )
Also the power supply values of IOMA for same core are:
P5- voltage = 0.00v
P15- voltage = 29.2v
N15- voltage = 0.00v
P24- voltage = 14.2v
N24- voltage = -14.3v
DCOM- voltage = 1.3 v</pre>
While S&T are normal.
I did the following procedures :
1.Replacing TCPS of core R without result.
2.Replacing TCQA no result.
3.Replacing TCQC no result.
4.Replacing SDCC & SLCC no result.
5.I swapping SDCC & SLCC of core T with core R,so the problem had transferred to core T, and all above voltages were correct at core R, but status of both cores was A6. so I returned each core to its place.
6.Replacing EEPROMEs of SDCC (DS200GHDQF1CBG 01&2) WITHOUT RESULT.
The diagnostic alarm is:
IOMA power supply out of limit, P5, P24, P15, N24, N15, DCOM.
There is no 125 v dc battery ground, and the voltages are +65.44 v & -65.4 v at core PD.
Also no difficulties, intermittent with the operation of the unit > So pls any solution for this problem.
P5v = 5.11 vdc
P5- voltage = 0.00v
