P
hello!!
can you help me..to set the right parameter settings of our schenck disoamat b? our present application of it, is through gas weighing scale (with load cell)..required weight of gas must be injected inside the sterilization chamber..(ex..15kg)...what must be the setting of schenck disomat b? as of now it can trigger injection but do not stop, even it reach the setpoint (15kg). pls help!! what must be the right parameter settings.
