Hi all.
I've developed a software to build HMI. It's Free and Opensource.
It is based on Modbus protocol, in particular on Modbus TCP/IP and works as a master node.
I've tested it on WAGO plc. I'm interested on the compatibility with any kind of device. If you are interested and use it, please notify the device you have used.
Suggestions are gratefully accepted.
Brief note: Right now the program supports:
- Read Holding registers 0x03 function;
- Write Multiple registers 0x10 function;
- Read Coils 0x01 function;
You can find it at https://sourceforge.net/projects/flexmodbus/
