Hello Fellows
I have an Emerson RTU talking to a SCADA server via VSAT and some intermediate Fiber Optic TCP/IP, Ethernet based network before data finally reaches SCADA server. This SCADA server only talks Serial (RS-232).
I am proposing to use Ethernet port on the RTU (programmed to handle TCP/IP Ethernet) to stay Ethernet all the way and use Ethernet to Serial converter at the SCADA server. But I am being told by vendor that I should have data coming out of RS-232 port of the RTU and in addition use a Serial to Ethernet converter before data is fed into VSAT. i.e. use two converters one at each end. I don’t think adding a Serial to Ethernet converter at the RTU end will add any value i.e. why first come out of RS-232 port and then convert to Ethernet as we can go straight Ethernet from RTU Ethernet port to VSAT. But vendor is saying that if data is not originating from Serial port of RTU then SCADA server will not read it.
Your help on this will be appreciated.
BJ
BJ
