Dear All,
I am working with Frame 6 machine, 32MW.
While going through P&ID of lube oil, trip oil and hydraulic oil circuit, I have noticed that Trip oil regulator valve's position is after 88QA discharge line and then after 88QE discharge is added to header.
VPR1 valve's setting is 4.75 Kg/cm2.
As far as i understand from reading manual, initially during turbine start-up when 88QA runs, as VPR1 (Normally closed valve) remains closed and first trip oil circuit charges and then after when trip circuit charged fully and VPR1 set point reaches and VPR1 starts opening and further lube oil circuit charges.
Am i correct till now?
Now my question is suppose in case of black start up (No power at all, Neither from grid), If we are going to start machine with 88QE (as AC power is not available to run 88QA) how it will charge trip circuit as, 88QE discharge is connected to header after VPR1.
And until unless trip circuit is not built, SRV will not open.
Kindly correct me and through some light here.
