P
Being new to hmi i need to set up the coms on panel builder 32 , it is a micro 300 2711-ma3-19L1 series A rev C.
The set up suggests that if rslinx is available it should be used . Now if i try to set up a 1747 pic driver in rslinx the displayed message is that the driver can not be established because linx is running as a service and not in the normal way .
If i shut down rs linx and try again the same message appears again as this unit requires dh 485 to be running. the problem is at the source, as i can not communicate with the panel. then pane builder gives me the standard message for the problem of packet time out check your cables make sure that printer port is disabled ,etc. i know that the cable is good, AS its the same cable used to communicate AND program with the micrologix 1000 plc but it uses DF1 coms and works fine.
in advance thanks again
