Every generator has got its own load angle. Some generators are connected to the same bus. Each bus has got a voltage & a load angle. If 5 generators are connected to a single bus & each generator has its own load angle, then how is the load angle of that bus determined? (....& yes i know that the angle of bus is also called "power angle")
