H
One of our Hitachi H25 gas turbine frame6 with GE Mark5 TMR speedtronic was out due to starting means problem. However the starting means problem is rectified and the unit was successful run up but the field breaker was closed manually but the bus and gen voltages were 11.2kV and 10.2kV respectively. The gen voltage never exceed 10.2kV when raised manual. On the HMI ex2000 error code 32767 is standing making it not to change to AVR mode from FVR.
Fellows I need solutions to the persisting problem.
