P
I want to know how to correct for liquid load or over reading on wet gas metering using cone meter?
Can I do it using two transmitters- the second tx place some distance after the cone element?
Both dP txs will connect to a DCS for totalising, metering calculation and with pressure & temperature compensation.
Can some one share your experience? Thanks
