F
For a change in de PLC software I also need to change/extend the Libnodave code, all running on a Linux PC.
My questions:
*Can understand code work? My C++ knowledge is quit rusty....
It should print a HEX code from DB22.DBD2 till DB22.DBD24<pre>
Bytes = 22;
res=daveReadBytes(dc,daveDB,22,2,Bytes,NULL);
if(0==res) {
for (a=1; a <= Bytes;a++)
d=daveGetFloat(dc);
fprintf(fp,",x" ,c);
} else
printf("DB22 failed! (%d)\n",res);
}</pre>
*Also when I want to compile the program the following message appears: "***no rule to make target 'log'. Stop"
"Compilation exited abnormally with code 2 at THU oct 13 10.51.00"
Thanks in advance for your advise.
My questions:
Bytes = 22;
if(0==res) {
d=daveGetFloat(dc);
} else
}</pre>
