Dear All,
I have a question regarding Modbus TCP/IP.
I need my Master and Slave device to communicate using Modbus TCP/IP. I'm using a Master device with an option for Modbus-RTU. Both Master and Slave device are interfaced using RS-485. So, Pals my question is can I interface both Master and Slave device using Modbus TCP/IP??? and between my Master device has an option for Ethernet (which is not enabled yet) but slave device hasn't got the option for Ethernet. should i use a gateway or a converter between these two devices to communicate??? or is there any other option.
Your help will be appreciated.
Thanks in advance
Anny
Thanks in advance
Anny
