Can someone please explain to me what is meant by running a Unit from Primary, Lean-Lean, Secondary to Extended Lean Lean or Premix? How does the turbine change stages, and what is it depended on.
T | Gas Turbine Premix combustion mode | Power Generation | 2 | |
A | Gas turbine combustion related problems | Power Generation | 4 | |
D | Reverse Power Combustion Turbine | Power Generation | 4 | |
H | Gas turbine combustion chamber | Power Generation | 2 | |
V | Turbine Tripping on "Combustion Trouble" & "High Exhaust Temp Spread Trip" | Power Generation | 6 |
