F
I have two UPS in parallel that communicate with a synchronization cabinet via Modbus TCP. The sync cabinet can communicate with other networks via Modbus TCP. All three of these devices have fixed IP addresses. I want to add the Sync Cabinet to my Modbus TCP (BMS) network so that I may obtain data from the downstream UPS as well. The UPS are at 192.168.001.011 and 192.168.001.021 respectively and the sync cabinet is at 192.168.001.001. I am unable to determine a subnet mask or default gateway.
My network is a 10.1.11.x with a subnet of 255.255.128.0 and a gateway of 10.1.0.2
I am thinking of using a router and NAT'ing the IP to one compatible with my network but have never done this before.
