Hello
I want to develop the following project:
I have several buildings where I perform periodically an energy audit.
Every building needs an energy sensor (modbus rtu), a water flow meter (modbus rtu) and a gas flow meter (modbus rtu). Every sensor is very far from each other, so one of my design criteria is go wireless (modbus over the air, ie: wifi, rf etc).
My main question is: what is the best and cheapest way to create this local modbus network (wirelessly) for every building and then gather all measurements from modbus device using a remote server.
More question
- Do I need a modbus rtu/wifi converter in every sensor?
- If I have two sensors very close, can I use a rs485-wire and connected to this wire a modbus/wifi or a ethernet/serial like (http://www.chiyu-t.com.tw/eng/products/i/bf-430431450.htm)
- Which is the main difference between a modbus rtu/modbus tcp and a ethernet/serial converter?
thanks
jaime
More question
thanks
jaime
