K
I have a problem where a pneumatic cylinder is operating a lot slower than required. The current set up has a 6 Bar supply, 6mm nylon air pipe approx 15 meters in length from the SOV to the cylinder (double acting), the sov has a 1/8 port and the cylinder has a 1/8 port. The cylinder bore is 2", a stroke length of approx 450mm and moving a weight of approx 270kg.
It is taking approx 30 sec to operate from limit to limit and i require an operation time of no less than 10 sec.
i would be very grateful for any help you could give.
