During a recent borescope inspection we found an IGV that snapped from its root on one end and yet somehow was not ingested into the machine. The IGV in question is located at the 6 o'clock position (the worst...) and we are now faced with replacing the vane. All possible causes aside does anyone have any experience with vane replacement? I've spoken to several expert and it seems like most feel the vane can be removed through the air inlet of machine with minor disassembly while some others claims the compressor casing etc need to come off and even a possible compressor rotor removal. It seems like a lot of work to replace one $1,500 vane so I'm hoping someone on here can confirm or deny that the vane can be removed without a major tear down. We do plan on replacing all 64 vanes and the rebuilding the IGV ring with new gears, bushings etc etc. Any help would be appreciated.
