I would like to know the formula to calculate the air flow (leak) is a starting pressure of the compressor 7bar and having a bore diameter 1mm. temperature 20C.
A | Ventilation Air Flow in 6FA GE Compartment | Power Generation | 1 | |
J | Purge Air Flow Rate | Power Generation | 3 | |
A | Air Flow Requirement for Pneumatic Instruments | Process Control | 5 | |
A | Air Mass Flow Rate of the Gas Turbine Compressor | Power Generation | 1 | |
P | Why Greater Than 30% Air Flow During Light Up | Power Generation | 5 |
