X
My application is as such.
1. Electromagnet is moved to workpiece.
2. Electromagnet is switched on, and holds on to workpiece.
3. Electromagnet is switched off.
4. Electromagnet is moved rapidly away from the workpiece.
My issue is massive arcing across the relay contacts.
I've already looked into snubbers to control the arcing, but I think a large part of the problem is that I am moving the magnet away rapidly and this is causing, due to residual magnetism in the workpiece, the electro-magnet to turn into a generator, causing another spike.
<b> Any thoughts, ideas, etc, on how I can help eliminate the spiking? </b>
Note - Someone else before me setup a snubber with a 7700uF cap and a 8.2ohm 3watt resistor, but they wired it in very strangely; it doesn't make sense to me
Note 2 - efficiency isn't an issue, heat isn't really an issue, has to be done as fast as possible
Disclaimer - I was trained in electromechanical, but it was pretty much mechanical & PLC's. So, I'm a bit new in this area....
Thanks kindly
Thanks kindly
