O
I'm new to this stuff so I need some help.
I have tried to connect Schneider Electric PM9C measurements trough Westermo EDW-100 to KepserverEX, but everytime I create tag to kepserver it says quality is bad. It also says Channel1. Device1 doesn't respond. Why does it shows that device. system connections are all good?
PM9C is connected by modbus to EDW-100 RS-485 port. EDW-100 configurations are changed to match PM9C (19200 bit/s baud, data 8bits, parity none and stop bit 1).
Is there some more configurations I should change?
EDW-100 and Kepserver use both same ethernet port (502) and IP protocol is TCP/IP. When creating device I used as ID: EDW-100 IP + PM9C address number. Device driver is Modbus TCP/IP Ethernet.
Running out ideas...
