Hello, first of all thank you for your help and ideas.
I have to measure water and gas consumption using some of the several flow sensors available in the market.
The question that appear when I have to choose one technology among all others is communications protocol (4-20mA flow measurements proportional to current in the loop, or a pulse pattern).
The main requirement is to make this measurement available in a modbus network (1 register for total consumption and other register for the rate of flow change)
4-20mA; it will require a proper calibration and a controller to estimate the cumulative water/gas used so far.
Pulse pattern: it will require a pulse counter and a frequency pulse meter, both variable will have to be available as a typical modbus slave device
from your experience: which is the best solution considering low cost implementation, cabling, and reliability
Thank you
Thank you
